  1. I'm using Pinnacle Studio 9 to upload my analog video to hard drive. It's working great but even a short clip is too large for email purposes. And zipping it up doesn't take it down that much. What's the best format to put a clip in for emailing and any suggestions on a converter? Thanks.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Convert the clip to MPEG2 or MPEG4. Look here for the converter:
  3. I'd personally suggest using VirtualDub to open it up, then convert it to a low-resolution, low-bitrate DivX file. That will compress it down nicely.
    You will find VirtualDub where Capmaster has pointed you to.
    Best of luck!
    Cobra
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Windows Media Encoder is free....and probably the easiest to open for even the most computer-challenged....like my brother. I send him Windows Media stuff all of the time.
    OR....follow what the other two have mentioned....
  5. thanks guys. I appreciate the help
