I want to put several small clips that I have onto a DVD. I know how to convert clips to DVD format but wanted to ask a question before I started this. Most of these clips are at a very low resolution or/and bitrate. When I convert them to the standard DVD format they become huge. If I just convert them to MPEG2 without modifying the resolution or bitrate of them will they still play on DVD players? Thanks.
Hello,
The best you could do would be to use half d1 resolution: NTSC 352*480.
The bitrate I think can go as low as 1150 (VCD bitrate as long as the audio is 48khz). Just do a test on a rw to test it.
Originally Posted by jimmalenko
Conversion Question: rmvb file via dvd player
By seifhatem in forum Newbie / General discussionsReplies: 5Last Post: 17th Nov 2010, 11:01 -
question about vhs to dvd conversion file type
By lotrmorgoth in forum Newbie / General discussionsReplies: 6Last Post: 1st Aug 2009, 10:33 -
Question about audio conversion to put VCDs on DVD
By jimdagys in forum Video ConversionReplies: 5Last Post: 28th Sep 2008, 22:07 -
Conversion Question
By sportflyer in forum Video ConversionReplies: 2Last Post: 21st May 2008, 09:40 -
Framerate conversion question (AVI --> DVD)
By kmmoore in forum Video ConversionReplies: 3Last Post: 19th Oct 2007, 09:47
