i've created 2 VCDs using Cleaner 5/Charger and TMPGEnc/VPC 4.0.
When played back on my Sony DVD player the video doesn't get past the first frame bit the audio is fine.
Anyone else experienced this and solved the problem?
some sorta copy protection. R u capturing the video through a capture card? if so then its prob a kinda macrovision.
Thanks but no it's not copyright. it's a PAL recording going through a PAL/NTSC converter, then into the Sony Media Converter and then my G4.
The PAL/NTSC converter conveniently ignores all copyright data and the Sony's Protect light doesn't come on.
I think its either too much or not enough Kbs.
Smooth frame by frame accelerated video playback?
By Malachaidc in forum Newbie / General discussionsReplies: 10Last Post: 30th Jul 2012, 12:40 -
extracting jpeg frame by frame from video
By goofymickey in forum ProgrammingReplies: 0Last Post: 16th Dec 2010, 08:02 -
Best software for Frame by Frame Video Edit?
By VEBouto in forum Newbie / General discussionsReplies: 5Last Post: 8th Feb 2010, 17:28 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 10:36 -
What Video editor's can cut frame by frame?
By VEBouto in forum Newbie / General discussionsReplies: 19Last Post: 28th Oct 2007, 02:31
