Results 1 to 10 of 10
convert the audio separate using for example ffmpeggui, open the avi, choose mp2, 44khz and 224 kbit. after multiplex/join the converted mpg with the new audio using tmpgenc, under file->mpeg tools->simple multiplexer
or extract the audio to wav and use it in tmpgenc when you convert
www.videohelp.com/virtualdubaudio
common tmpgenc problems:
www.videohelp.com/tmpgenc#problems -
i have no idea how to do any of those, isn't there any thing that can covert both video and audio at the same time?
Originally Posted by LAX
https://www.videohelp.com/tools?toolsearch=&s=&orderby=Name&hits=50&convert=AVI+to+VCD&...+or+List+tools -
You may also want to try another encoder. MainConcept MPEG Encoder is a good choice.
Originally Posted by LAXThe distance between genius and insanity is measured only by success...
i figure it out
and now my 698 mb avi file comes out 608mb mpeg and burn and plays great on my dvd player
jyn999: PLEASE stop using the bbcode url for urls....
...it doesn't shrink the longs urls...and no I can't fix it so it does.
Resolved: Use Subtitle to Create Border on DVD Without Re-encoding
By sambat in forum SubtitleReplies: 6Last Post: 26th Feb 2012, 07:07 -
I've resolved so much, but still have an encoding question...
By takearushfan in forum AudioReplies: 10Last Post: 9th Jun 2010, 09:25 -
[RESOLVED] Anyone with a Sony PD100A?
By MarkMission in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 19th May 2010, 14:04 -
*RESOLVED* resetting password on a networked HP printer? *RESOLVED*
By Xylob the Destroyer in forum ComputerReplies: 3Last Post: 21st Nov 2008, 13:50 -
DVD Shrink Pause Issue - Problem Resolved with v2.5.3200
By k_vic in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 18th Sep 2007, 02:58
