Bought a "cheap/basic" Splitter Amplifier yesterday wanted to give a little enhacement on TV capturing.
On the first few trial, I found the picture quality worst than without using amplifier.
Then after few more tries (like adjusting the gain control switch), I can only hear the "background sound". All the voice from TV was lower almost you can't hear it.
The picture just look like normal.
Can anyone tell what had happen to my card? Did I just fire it?![]()
Not only happen on TV input, from the AV composit input as well!!!
When try to input from VCR, the sound was very low even you turn the volume to high.
If I capture it (huffyuv/PCM), the picture all right but the sound, like "come from far away". (Sure dosen't sound alright.) -
btw, i had already remove the Splitter Amplifier.
It's seem like it damage my card, is it possible?
Menu background sound in multi avchd
By DODGEYONE in forum Newbie / General discussionsReplies: 1Last Post: 20th Nov 2011, 13:13 -
No sound on movies, only background
By N3kr0 in forum Media Center PC / MediaCentersReplies: 1Last Post: 19th Jul 2011, 17:21 -
Need to know to find & disable background processes
By Danae in forum MacReplies: 16Last Post: 11th Aug 2010, 22:23 -
Problem with Background sound using AVI2DVD
By govtstooge in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 14:11 -
Hissing Sound in the Background
By Jenny in forum Newbie / General discussionsReplies: 2Last Post: 10th May 2007, 01:04
