I am a newbie, I have tried the reading and search but I might be searching for the wrong stuff. I have a mpg file that is about 790 mb. I want to fit it on a cd that is 700mb. I figure I have to compress it. So I have been searching for stuff to do that. The first time I tried to convert it ( or compress it) I ended up making the resulting file bigger. It was about 6 gigs, then I tried TMPG. the wizard would start up and everytime I tried to load the target file, it would shut down. So could anyone please help me or point me in the right direction. Thank you for any help.
j
Results 1 to 10 of 10
I'm going to guess your MPG file is VCD ready. Try burning it to a CD in VCD format. You can fit over 800 MB in VCD format because it uses fewer error correction bits than data CDs.
The file is a mpeg1 file. It was a SVCD file but I used isobuster to extract the video and audio from it becuase I burned it to cd but it would not play on any of my players so I just wanted to watch it on my computer. I can watch it now, but I wanted to burn it to a cd to take with me, it's just a lil too big. Thanks again
j -
Yeah my computer does play it, the problem is I am trying to fit it on to a CD and it is 790 mb, the cd is 700 mb. I am trying to figure out how to make it smaller. When I burned it as the svcd file it wouldn't play. Thaks again.
j -
Video disks use less data protection than data disks. an 80min 700Mb disk will hold 800Mb of video. Also you can overburn a little.
Get the free version of VCDEasy 1.5.2 and either create an image there or burn directly. If your file is mpeg1 then create a VCD, if it is SVCD (ie mpeg2) then create an SVCD. VCDEasy has the settings to permit overburn. -
ok I will give these options a try, thanks. Will I be able to play the vcd on my computer using the windows media player?
fit 3 movies to dvd5
By thecrock in forum Newbie / General discussionsReplies: 9Last Post: 19th Jul 2008, 15:00 -
auto fit
By roystheboy in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Jun 2008, 06:23 -
makin the movie fit
By xstatictravis in forum DVD RippingReplies: 12Last Post: 11th Apr 2008, 09:52 -
How many can I fit on a DVD?
By love2learn in forum Newbie / General discussionsReplies: 1Last Post: 17th Nov 2007, 12:46 -
Help to fit two DVDs into 1
By heretic1 in forum Authoring (DVD)Replies: 1Last Post: 12th Jun 2007, 23:57
