Hi all - I did some searching and still haven't found an answer on this.
I ripped using DVD Shrink's latest 3.2 using the Backup, selecting a single Title and backing up to a video_ts folder. When importing this into TMPG DVD Author it comes back with the error "GOP is too long." Many recommend simply hitting Ignore and forgetting about it. I tried this and the video is choppy, both in computer playback of the VIDEO_TS folder (WinDVD 6) and a burned DVD-R.
I also tried ripping demuxed streams using DVD Decryptor. Same error whe importing into DVD Author.
Any clues? I haven't seen much discussion on this. Is there any method of fixing this?
I have a bunch of SVCDs that I created in the past before I moved to DVD. They were made with DVD2SVCD and all of them have the error 'GOP too long'. I ignored it and burned anyway and they all play on my settop.
I think jimmalenko has a better idea to make them standard, though I have had good luck with my 'no' method. -
This was a retail DVD I own, so I think the issue is rather DVD Shrink.
I tried out Nic's ReJig as recommended in another thread, but didn't see a "GOP fix" function of any kind...will try MPEG-VCR now.
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 08:36 -
Which GOP program?
By pboong in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 12:19 -
Closed GOP
By kitty in forum GlossaryReplies: 1Last Post: 12th Feb 2008, 23:14 -
Questions about GOP.
By Sean_ve99 in forum Newbie / General discussionsReplies: 11Last Post: 8th Jun 2007, 23:08 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 09:40
