I am struggling to get my Device Manager to reckognize my Canopus ADVC-100.
The 1394 card installed for the purpose of using the ADVC is acknowledged under Device Manager but nothing I have tried produces an "Imaging Device" entry.
Canopus have sent me several files/drivers to install without success, I have used different slots for the card (a VIA chipset card), different cables, different ports on the card, booted up with the ADVC attached/not attached, all without result.
I am using a Jetway V266B mother board, AMD Athlon 1700, 256 mb RAM (soon to be upgraded as I realise this is low for effective capturing/editing use) XP Pro with SP1. DirectX 9.0c is installed.
Any help with this problem would be very much appreciated as many users of this device must have a similar set up.
I did try a NEC chipset 1394 card but that wouldn't even permit the PC to turn on. It was precumably defective and has been returned for replacement.
The next thing to be replaced is me if I don't get some results soon!
This is the result the result of a "dxdiag" run on my system, with some of the standard stuff (mouse, keyboard, soundcard,etc.) edited out to reduce the size.
System Information
Time of this report: 10/19/2004, 00:41:10
Machine name: MYCOMPUTER
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp1.020828-1920)
Language: English (Regional Setting: English)
System Manufacturer: JETWAY
System Model: AWRDACPI
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: AMD Athlon(tm) XP 1700+, ~1.5GHz
Memory: 256MB RAM
Page File: 129MB used, 489MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/7/2003 12:00:00, 51968 bytes
| Driver: usbd.sys, 7/7/2003 12:00:00, 4736 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 16.2 GB
Total Space: 38.2 GB
File System: FAT32
Model: ST340810A
Drive: D:
Free Space: 5.8 GB
Total Space: 12.4 GB
File System: FAT32
Model: Maxtor 91301U3
System Devices
Name: VIA Tech CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B099&SUBSYS_00000000&REV_00\3&61A AA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP.SYS, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 27392 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1106&DEV_3147&SUBSYS_00000000&REV_00\3&61A AA01&0&88
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 7/7/2003 12:00:00, 35840 bytes
Name: VIA Tech CPU to PCI Bridge
Device ID: PCI\VEN_1106&DEV_3099&SUBSYS_00000000&REV_00\3&61A AA01&0&00
Driver: n/a
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_00000000&REV_46\3&61A AA01&0&50
Driver: C:\WINDOWS\System32\DRIVERS\ohci1394.sys, 5.01.2600.1106 (English), 8/29/2002 01:33:20, 55680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\1394bus.sys, 5.01.2600.1130 (English), 10/7/2002 13:01:16, 50688 bytes
Driver: C:\WINDOWS\System32\DRIVERS\nic1394.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 57984 bytes
Driver: C:\WINDOWS\System32\DRIVERS\arp1394.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 57344 bytes
Driver: C:\WINDOWS\System32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 13:46:40, 6400 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_23\3&61A AA01&0&8B
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 135552 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 51968 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 22:36:34, 67072 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_23\3&61A AA01&0&8A
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&61A AA01&0&89
Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000 (English), 7/7/2003 12:00:00, 4864 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.1106 (English), 7/7/2003 12:00:00, 86912 bytes
A little knowledge is dangerous. What does this button do...............
Try upgrading to Windows XP Service Pack 2. Here's a webpage from Microsoft that describes the problem:I am struggling to get my Device Manager to reckognize my Canopus ADVC-100.
http://support.microsoft.com/default.aspx?scid=kb;en-us;329256
If that doesn't work, uninstall the both Firewire card and the Canopus unit using the Windows Device Manager. Reboot and Windows should find both devices and will reinstall them. -
Thanks for the thoughts Jabloomf1230 but the particular file suggested by MS from SP2 has already been installed having been sent by Canopus Tech Support.
I've Uninstalled, reinstalled and the Device manager reports "New Hardware found, AVC device found, etc" but it still doesn't appear in the List of Devices and software to capture video doesn't see it as installed.
Any more thoughts or experience from ADVC-100 users?A little knowledge is dangerous. What does this button do............... -
With your PC off, and the connection to your PC disconnected, connect your camera or VCR or whatever to your ADVC and turn your ADVC on. Does it correctly select the Digital or Analog input (one of the blue lights should stay lit after about 5 seconds) ?
The reason I ask is that my ADVC-100 had a dodgy power supply and would get picked up by the device manager. The telltale sign was that when I turned it on, both lights as well as the status light would stay lit. After getting it fixed, I get all 3 lights lit up for about 5 seconds, then the appropriate blue light remains lit.
Just a thought.If in doubt, Google it. -
Thanks for taking the time to post but, yes, the signal detection works correctly.
And I thought this was the easy way to transfer Analogue video!
I am very suspiscious that the problem lies somewhere in XPPro/SP1 & DirectX 9, iven the amount of problems reported on the Canopus Forum after users have upgraded (?) to SP1 and DirectX9
Any further thoughts....................A little knowledge is dangerous. What does this button do...............
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 09:41 -
Stylized "RW" logo found on blank media packaging - what does it mean?
By ibzomie in forum MediaReplies: 3Last Post: 30th Dec 2011, 08:48 -
AVStoDVD does not start... says "VB6 Common Controls not found!"
By granturissimus in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2011, 08:15 -
BR structured image file is found as "unsupported"
By besthost in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Jun 2009, 03:06 -
Divx Player Error "NO Recorder Found"
By vitonxl in forum Software PlayingReplies: 3Last Post: 21st Jan 2008, 22:34
