I recently burned 2 dvds which do not play on the standalone player. someone asked if they had errors on them because computer dvd players have better error correction. is there any tool that can scan dvds to analyze how many errors it contains (if any) and maybe some other valueable information that might help debug why this isn't playing? thanks!
Results 1 to 10 of 10
Scan with DVD Info Pro. A few details would be nice
What software did you use? Which burner? Which discs? Which standalone?
He's a liar and a murderer, and I say that with all due respect. -
sorry abou that. didn't bother posting because another thread suggested that might be the problem..figured i'd get to the point. at any rate here is the info:Originally Posted by steveryan
software used: dvd decrypter, dvd shrink, tmpgenc author
burner: khypermedia (rebadged benq) 8x
discs: piodata (supposively they are Ritek)
standalone: sony SLV-D300P
thanks again! -
Well I usually leave verify on when I'm burning either my only copy of something, or something for other people. That right there rules out totally bad burns... but not "low quality" burns.
If you had a liteon, the tool to use would be KProbe, although that has been less than reliable on certain liteons. CDSpeed tests, so does DVDInfoPro, IIRC. -
thanks again for the replies all. i just ran DVDinfoPro and it detected no errors on my disc. any other things i can can, or it's safe to assume it's the media that is disliked?
are you sure this isn't another program? can't seem to find this feature...not even listed in the help section.Originally Posted by samijubal
Open DVDInfoPro, look at the top where it says PI PIF, I think your drive is supported.
I searched the whole program (version 2.64), no sign of PI PIF unfortunatley. I guess my drive is not supported ;/Originally Posted by samijubal
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum Capturing and VCRReplies: 1Last Post: 16th Nov 2009, 01:11 -
VideoReDo Not Detecting Audio
By MegaTonTerror in forum Video ConversionReplies: 3Last Post: 11th Nov 2009, 15:39 -
CRC errors when copying DVDs
By Shadowofthedarkgod in forum Newbie / General discussionsReplies: 7Last Post: 1st May 2009, 03:59 -
Detecting static/noise in video
By tripecac in forum EditingReplies: 10Last Post: 17th Jul 2008, 08:53 -
NoScript detecting spb.ru
By GMaq in forum FeedbackReplies: 0Last Post: 16th Aug 2007, 11:34
