I have a great capture from an ATI HD tuner card. The quality is outstanding even after transcoding from its proprietary ATI format to MPG. My problem is the sound was Dolby 5.1 and my Authoring software (Ulead DVD Movie Factory which has been *great*) doesn't appear to support it. After I authored there was no sound at all. I am not concerned about retaining the Dolby 5.1 I just need sound. How do I convert this so DVD Movie Factory can author it properly with just normal sound. I believe there were 2 settings in Ulead for audio LPCM and MPEG audio. I used LPCM which I thought was correct??? Will I need a different program all together to convert this audio??? Can VirtualDub perform something like this??? Will I have sync problems???
Y
why not author with a tool that supports 5.1? like tmpgenc dvd author , dvd-lab.
Check out guides associated with BeSweet (spelling ?) - it may hel you out.
I agree with Baldrick on this one though - if you already have a solid 5.1 audio track, why sacrifice it because your authoring program can't handle it ? Both the options Baldrick mentioned are relatively cheap, and can handle AC3 audio.Read my blog here.
Thanks for the guidance. I will post my results whichever way I go.
Y -
do you have a link to the card you're using? Is it this one?
http://shop.ati.com/product.asp?sku=2546404 -
I could be wrong, but doesn't TMPGEnc DVD Author only handle Dolby 2.0 ?
EDIT:
From http://www.pegasys-inc.com/en/product/tsp_ac3.html:
Thanks to it, it is possible to decode and encode in
Dolby® Digital (AC-3) 2ch audio with products that support the plug-in...
Dolby Digital with 5.1 channels or other multi-channel sources cannot be encoded...
Changed or added features when TMPGEnc Plug-in AC-3 is integrated
-Possibility to specify "Dobly Digital audio" for output
In the audio setting, the choice Dolby Digital (AC-3) appears, you can then choose Dolby Digital for output.
-Re-encode Dolby Digital audio
When you are using source files with Dolby Digital (AC-3) audio, for instance, files made from a DVD-recorder
or MPEG files, you can re-encode the Dolby Digital audio. And choose the track setting:
mono, stereo, or dual channel (for bilingual broadcasting / used in some coutries).
*But Dolby Digital (AC-3) with 5.1 channels or other multi-channel sources cannot be re-encoded.If in doubt, Google it. -
Tda imports ac3 5.1 to be used as is but doesnt encode 5.1 to 2.0.
Sorry to bring this old topic back. However, I need to know if the above is true for NeroVision.Tda imports ac3 5.1 to be used as is but doesnt encode 5.1 to 2.0.
I am trying to author some .VOB files with NeroVision to a DVD-R. The files are in Dolby 5.1 and I need to know if NVE will encode them to Dolby 2.0 (Since is the format it support with the plug-in) or it will use them as 5.1 (original audio)
I want my DVD with the 5.1 audio. So, if the NVE will change them to 2.0, then what will you recomend to author them with the original audio?
I have also read that you can use DVDShrink to do it, if you create the .ifo files with IfoEdit. Are there any guides that can help me to do it with this method?
Thanks for your help.
Rey
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 20:51 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 15:30 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 20:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 17:54 -
Does removing DTS sound in movies help Dolby?
By JohnnyBob in forum AudioReplies: 22Last Post: 11th Sep 2007, 16:53
