I have mpeg files that I want to convert to file types that after burning to dvd are in format that I can play on my standard dvd player.
Please your help I spant a lot of time and lot of dvd discs that are not playable on dvd player.
Thanks in advance.![]()
Hello,
You need to author them in programs like tmpgenc dvd author, ulead dvd movie factory, dvd lab, etc... Then you'll get a video_ts folder with vobs, bufs, and ifos that will be burned to the disc.
https://www.videohelp.com/author
That link should help.
But first, your MPEGs must be DVD compliant - see "What Is... DVD" link in the top left of the page for specs for your region (PAL / NTSC - Hint: update your profile with your location). You can use AVICodec or GSpot to get most of the info on the file(s).Originally Posted by yoda313
P.S. I notice it's your first post - welcome to the forum.
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room.
how to convert dvd with dts audio to a dvd playable on a dvd player
By flannob in forum Newbie / General discussionsReplies: 5Last Post: 19th Sep 2010, 07:46 -
Help convert avi to WD HD Player -Playable format
By anbures in forum Video ConversionReplies: 1Last Post: 7th Nov 2009, 06:27 -
How do i convert .avi files to be playable on a dvd player?
By Beautiful Alone in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2008, 05:03 -
Convert from FCP output (DV-PAL) to a format playable on PC in WMP
By Ferry99 in forum Video ConversionReplies: 1Last Post: 24th Dec 2007, 20:32 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53
