Ok, I have a Philips DVD+RW DVD8601 that came with my dell. Been having some problems with it and you guys have helped so far so I thought I would ask another question. Some other forums have suggested changing the firmware from the Philips to a BenQ1600 firmware. What would this do and why is it recommended? I am considering doing it if it makes the drive better but I would like to know HOW it makes the drive better. I already have the instructions and files I would just like a little more info.
Thanks!!
Okay, I made a mistake. The firmware is to upgrade it to a BENQ1620, not 1600. Anyone know the advantages of this over the normal Philips firmware?
Assuming it's the same drive, I would say that Benq has a larger base of unofficial firmware compilers (see cdfreaks for reference) so you'll be more likely to fix any bugs the original one should have.
(The firmware dictates the writing strategies, so better firmware=better burns)
Anyway, cdfreaks is the place where you can find all the info you need, you should check it out first
(if the suggestion you were given came from cdfreaks then I would seriously follow their advice)Sorry, I had to go see about a girl -
This thread tells how, 6th post down.
http://club.cdfreaks.com/showthread.php?t=110931
Can Philips 5990 firmware be used on Philips 5992 Dvd Player
By peggypwr1 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Mar 2010, 17:06 -
BENQ DW1670 issues
By kyrcy in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th Jan 2010, 18:00 -
Which Benq DVD burner is the best
By Habby in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Oct 2008, 13:43 -
BenQ firmware can't handle 8X DL
By miamicanes in forum DVD & Blu-ray WritersReplies: 8Last Post: 5th Feb 2008, 14:27 -
BenQ DW1640
By jeet49 in forum DVD & Blu-ray WritersReplies: 2Last Post: 12th Nov 2007, 18:48
