On my Magnavox MRV640 recorder I attempted to add channels automatically and manually. Manually I can register 69 channels that use the antenna and that is ok. With cable I can add channels from 1 to 125 and that is not ok in as much that my cable TV goes up to 840 channels. Regardeless what I do I cannot go beyond 125.
Did anyone else have this problem.
Thanks, bulach
This is normal. The tuner inside a VCR or DVR only gets these channels. To receive the higher channels you need a cable converter box which is not built in to the DVR. If you previously had a VCR, this is just the same.
How your record those higher channels depends on how you've connected the DVR and the cable box together. The DVR's installation manual may give you guidance on this. -
I believe IR blaster is what you need to hook up, but surfing will be slow. Should be in your manual.
Frobozz is right, your recorder only has an analog tuner. It can't get all the digital channels. You'll have to use your cable box for that.
Thank you for the reply with helpful info, Frabozz-sirtfus-junkmalle. I reviewed the hookup according to the manual and made the necessary change. Now it works just fine. Us new kids on the block are fortunate for your assistance. One day I hope to help someone.
bulach
Is there a DVD Recorder that can record Subtitles from HD channels?
By MounaLafi in forum DVD & Blu-ray RecordersReplies: 9Last Post: 14th Mar 2011, 15:32 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 16:07 -
Sony RDR-GX300 DVD Recorder can't record channels 200+?
By showmi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 8th Jul 2008, 14:49 -
DVD Recorder that allows digital channels to be added?
By VideoJockey2002 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 18th May 2008, 17:58
