Results 1 to 10 of 10
  1. i have d/l and installed virtualdub 1.5.10 , followed guide on this website,clicked file> open video file
    it then 'parsed' avi (sorry can't remember exact wording)
    i then clicked file > to amend video segment but it was not highlighted!!!
    also i cant do a direct strream copy of the video as the source video stream uses compression algorithm not compatable with avi
    i am really confused!! have i got the wrong version,or are the avi files corrupt,all codecs are present,will have to try filemerger if not successful
    what is the source video? use gspot or avicodec to identify the source. just avi doesn't say much.
  3. Originally Posted by keeny
    open video file
    Sounds like you opened an MPEG file. Its append function won't work with MPEG files.
  4. hi- the source was a .bin file,i extracted the video with isobuster , and saved the 2 files as .mpg files-please tell me which file types i should have used?
    thank you
  5. I believe that TMPGENC will joing the two videos, just be warned that there may be an audio lagging/speed up issue where the 2nd video/audio starts.
    I believe that an app called avi joiner will do what you want. I've never used it, but the app name cant just be a clever name. Can be found in the tools section.
  6. Originally Posted by keeny
    thank you
    Bin files are disk images. Isobuster is an extraction program. Itjust extracts the files that are in the disk images.
    You can use Womble MPEG Video Wizard to join the two mpg files together without re-encoding (if they have the same properties). But why do you need join them?
  7. hi-its a film, that once i have joined the files would like to convert and burn to dvd
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    www.svcd2dvd.com and you don't have to join, the author tool will join the video. you can also use tmpgenc dvd author if it is vcd or dvd-lab if it is svcd.
  9. hi-thank you will try,just looking for a d/l of version 1.0 of svcd2dvdmpg as your guide looks nothing like the latest version,i dont want to change anything,will be happy to keep it simple,thank you
  10. hi-i used svcd2dvdmpg to convert the files,then authored with tempengc dvd author ,there was a slight pause as my player treated it as 2 tittles,i am thinking of donating to svcd2dvdmpg to get the authoring tool and see if it does a better job
