Hi,
I've made a rip from a dvd with simpledivx. But there must have been something wrong, because i have only an avi file with no audio, and a mp3 file. Both seem to be correct, but how do i have to join them togheter to one avi file?
regards,
you can use virtualdub, https://www.videohelp.com/faq#multiplex
Hi,
thanx for the respond but it doesn't work. Virtualdub only supports wav files, so i cant do nothing to join the mp3 with the avi -
use virtualdubmod, open the avi, add the mp3 under Stream->Stream List, select Video->Direct Stream Copy and last File->Save as.
(I updated the faq...it hadn't been updated in a some years)
Baldrick's answer was based on the fact that you CAN select an MP3 with vdub.
Are you converting this to Mpeg2 now? If so you can always multiplex the avi when converting. Just select the mp3 as the audio source and you should be all set.
Oops, Baldrick beat me to it!
How to join 2 avi files into one? together with Audio with avisynth + megui
By squall0833 in forum EditingReplies: 7Last Post: 11th Jul 2010, 09:47 -
How to join AVI files with multiple audio streams
By V@no in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2010, 22:17 -
Simplest way to convert and join avi's with different audio streams??
By Lolipop Jones in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2008, 11:25 -
How do i join video and audio file together
By ultraman36 in forum EditingReplies: 1Last Post: 15th Jan 2008, 17:24 -
When i join ssa+avi the video is messed up
By noskid21 in forum EditingReplies: 3Last Post: 17th Jul 2007, 13:02
