Hi all.
can anyone help..i have a pioneer 106 dvd burner, i have had it for a year or so..i have been using the same media as i always have..but today after trying to backup a movie error messages are poping up..one said problem reading disc(using tmpeg movie author)..another said "runtime error" after 99% of the dvd was burned,(that was using dvd decrypter)
and i when i insert a dvd into the drive it tells me that there is nothing on the disc.
the disc is a manufactured dvd so i know it works.
is my burner up the spout?
is there some thing i can try to determine wether it has had it?
cheers.
I have a similar problem. All of a sudden, my 106 burner will only burn
"-" media, no "+". As a matter of fact, 20 minutes earlier it was burning both format.
No new application was installed nor any changes to the PC.
Does any body have any idea what happened or is it time to upgrade?Never too old to learn -
The 105's and 106's are prone to dirty lasers.
I have dissasembled and cleaned quite a few.
The problem is compounded if you are a smoker.
I use q-tips and denatured alcohol to clean the lens.
Others have had success with commercial disk
cleaners, but I have never tried one.
kiki
How does HD Writer do it?
By OldNick in forum Authoring (DVD)Replies: 7Last Post: 11th Mar 2012, 20:57 -
Best writer in a duplicator
By Habby in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Mar 2008, 04:00 -
Best AVI Writer?
By ouxch in forum DVD & Blu-ray WritersReplies: 13Last Post: 5th Jan 2008, 03:31 -
After a new DVD Writer..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 28th Nov 2007, 11:01 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 01:08
