I was trying to convert WAV files to AC3 in ACID but after I load the WAV file the "render to" option under files is dulled out and can't be selected. The AC3 plug-in is installed. Am I trying to do something the plug-in doesn't support? Will the Vegas package do this?
Hi JDShaffer,
You can use ffmpeggui to do WAV to AC3 2.0 (i.e. 2 channel). It won't do AC3 5.1.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
acid and vegas use the same encoder ... you sure you have it installed correctly and that you have registered it ?
contact sony and they can help you with your registration ..
the ac3 surround package is purchased separately from acid ..... it also comes with DVDA"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
you mean acid supports the DVD-Audio standart?the ac3 surround package is purchased separately from acid ..... it also comes with DVDA
CYA Daphy -
no - i mean acid can encode to ac3 5.1
DVDA is the way DVD Architect by sony is often referred as ..
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 08:00 -
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
how to transcode from AC3 to WAV
By phpmysql348 in forum AudioReplies: 3Last Post: 7th Sep 2008, 00:46 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 04:03
