i have many VCd dat files i want them to convert to DVD and burn on one DVD-r ,,,so exactly how much .dat CDs can i convert to single DVD-r
so that i can watch on DVD player and which software allows me to do that very easily,,,because i am not so expert,,so which software is user friendly in doing that
thanking all
Hello,
Use isobuster to extract the .mpg file.
Then you can use an authoring program like tmpgenc dvd author to convert the audio to dvd specs. You can fit up to 4.37 gb on a dvdr so it's almost as much as you can fit (depending on how elaborate your menus are of course, those add space).
the software you need is TMPGnc DVD Author.
Once you have that program, try this first, re-name the extension from .dat to .mpg directly. load the re-named file into TMPGnc DVD Author, if it accepts it, you have your luck because it will NOT re-encode your video, it only re-samples the Audio from 44.1 to 48khz. If TMPGnc DVD Author rejects your re-named file, then you use VCD Easy to convert the .dat file to a TRUE .mpg TMPGnc DVD Author will accept then. Good luck! -
Use vcdgear to convert the dat files to mpeg, it only takes minutes and doesn't involve re-encoding. There are plenty of guides to do the rest.
I could dance with you till the cows came home..... on second thoughts i'd rather dance with the cows till you came home.
Rufus T. Firefly (Groucho Marx)
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 09:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 01:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
