I've converted ogm files to avi before following the guide here: https://www.videohelp.com/forum/viewtopic.php?p=1018674#1018674
and never had a problem but this time when i tried to save the ogm to a avi file the avi turns out to be over 24GB and takes up my whole drive and it still isnt done after filling up the drive so i dont even have tho whole thing. Is there another way to do it or is there a way to compress it? i cant get past adding the mp3 and then saving it. [/url]
You must use Direct stream copy(you find it under Video->Direct Stream Copy in VirtualdubMod). If you are usig Full processing will the video be uncompressed.
i was using the direct stream copy. the thing is that if i save it and it doesnt turn out to be over 24gb, and i try to open it with gordianknot it says that its not a corest dv2 or avi file. could there be soemthing wrong with the ogm?
why use gordianknot? reencode the video again???
what does gspot say about the avi?
.ogm file
By d_animality in forum Authoring (DVD)Replies: 2Last Post: 29th Aug 2011, 09:19 -
How to Convert OGM!?!
By SamohAD in forum Video ConversionReplies: 6Last Post: 19th Mar 2009, 19:42 -
.OGM help
By Moparbear in forum Video ConversionReplies: 2Last Post: 3rd Mar 2008, 20:08 -
.ogm to DVD
By Faty100 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jan 2008, 11:14 -
OGM remuxer?
By Colmino in forum Video ConversionReplies: 1Last Post: 25th Nov 2007, 14:27
