Hello all,
I have this device which I use to capture from my HI-8 tapes on PAL system.
Anyway, I would like to know what chip does it use for capturing?
Also, I am few softwares to capture my video tapes.
Seems like no matter what software I use, or what settings I choose, the overall quality is always inferior to the source, hence, at times it is not smooth, is this because frames are dropped? At times the video+ audio do not sync, why does this happen?
Any advice will be appreciated.
Thank-you.
Results 1 to 1 of 1
If it's working... don't touch it.
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Looking for a device that connects multiple usb2 hdds in series ?
By vhelp in forum ComputerReplies: 4Last Post: 24th Apr 2010, 06:43 -
Buffer Device question:
By butt_crack in forum DVD RippingReplies: 1Last Post: 5th Feb 2010, 12:35 -
HD Pvr 1212 - device is not connected - can't use device in arcsoft softwar
By yoda313 in forum Capturing and VCRReplies: 9Last Post: 16th Aug 2009, 18:22 -
technical question on center ch. of Dolby Digital
By dondeaida in forum AudioReplies: 5Last Post: 19th Aug 2007, 09:11
