Poll: PowerDVD or WinDVD
Be advised that this is a public poll: other users can see the choice(s) you selected.
Results 1 to 18 of 18
  1. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    Which is your favorite software player between these two?
    Plesae dont turn this thread into a flame war. Just want your opinions.
    Mine is PowerDVD.
  2. Me too.
    I use Power DVD 4. Power DVD 5 seems to have bugs on some mpeg-2 files (artifact apprears like a damaged mpeg file).
    PowerDVD. But Media Player Classic is enough for me.
  4. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    I use to use Windvd but powerdvd came with my dvd burner and I've been using it ever since.
    Kevin
  5. Mod Neophyte redwudz's Avatar
    USA
    I use an older version of PowerDVD, version 4, I think. I have a newer version, but it just wants to play DVDs while the older one is more universal, simpler and will play most any MPEG file.
  6. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    I use PowerDVD for playing dvds, but use Media Player Classic for everything else.
  7. Banned
    Sep 2004
    Inner Circle of Thought
    I use PowerDvD 5.
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    PowerDVD for mine.
    If in doubt, Google it.
  9. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
  10. Member jabloomf1230's Avatar
    Jan 2004
    Eastern N.A.
    PowerDVD, but there's certainly room for improvement/flexibility vis a vis Zoom Player.
  11. Member tekkieman's Avatar
    Mar 2004
    Over the hill
    Used both. Prefer PowerDVD. Tried both ver 4 and 5 of PowerDVD. Prefer 4.
  12. PowerDVD 5 for DVD's.
    I switched from WinDVD after having constant trouble with various discs not playing correctly (mainly garbled/scrambled audio). I have not tried the latest version, though.
  13. Member OverBurn's Avatar
    Jul 2004
    Voted for PowerDVD, but mainly use Nero Showtime for DVD playing now.
  14. power dvd because it will play dvd dts audio only files rip dvd dts files with dvd audio extractor play files with power dvd
  15. Member SLICK RICK's Avatar
    Mar 2003
    Houston, Tx by way of N.O
    PowerDVD here.
    Nobody likes a bunch of yackity-yack.
  16. Member waheed's Avatar
    Jul 2003
    Manchester, UK
    PowerDVD 6 is now out.
    This includes support for DVD Audio for those with Audigy 2 series of sound cards.
    see for your details:
    http://www.gocyberlink.com/english/products/product_main.jsp?ProdId=28
    Australia
    Use both.
    I have PowerDVD XP - I use this more often because it loads faster than WinDVD, however it has a 4gb limit on opening files - crashes on files > 4gb so to play these I switch to WinDVD which has no file size limit.
  18. Originally Posted by cd090580
    Me too.
    I had the same problem and found PDVD 4 to be rock solid.
    I tried WinDVD 4 and found it to be unstable and harder to navigate.
