Hello all..
I have a problem. I rip a movie with DVD shrink. Burn it with the latest Nero version on a Richo DL disc.
Works great on my DVD drive but on my Pioneer(latest model) standalone it works crazy.. I can start the move. Watch the movie. But if I for example choose the languge menu I can not use the menu. It only says forbidden action when I puch a button on the remote. This always happen. The main menu works fine though.
Chris
Cinema Replicas -
Try ripping it with a tool intended for that purpose... DVD Decrypter for example. Make sure to turn off PUO's.
Also, DL burning is far from an exact science at this point.
Turn off? You mean I should remove it from the disc when I rip?
Chris
Cinema Replicas -
Go into the dvd shrink preferences and un check remove layer break before burning dual layer Dvd-9.
James B Elder
VOB2MPG-PRO: Problem extracting VOBs from Verbatim DVD+R Dual Layer (8.5GB)
By rickyp513 in forum DVD RippingReplies: 1Last Post: 25th Aug 2010, 17:47 -
Dual Layer problem. Layer break issue...
By papegoja in forum DVD RippingReplies: 23Last Post: 9th Jun 2010, 23:52 -
HELP!! Dual Layer Problem with Titanium 10
By mnelson220 in forum MacReplies: 20Last Post: 21st Jan 2009, 00:50 -
Problem Writing Dual Layer (first time attempting DL)
By brett0973 in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2007, 22:46 -
dual layer DVD-R in single layer burner?
By snafubaby in forum MediaReplies: 5Last Post: 4th Oct 2007, 14:39
