Hi
I have a question:
If I have 2 SVCD files is there any way I could merge them ?
Thx in advance.
Results 1 to 21 of 21
JKoniak
Hi jarko,
One of the following may do the trick:
FileMerger
VideoReDo
There may be others...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
What are you trying to do by merging the two SVCD files?Originally Posted by jarko
I have dvd/mpeg/vcd/svcd player and I want to put these 2 svcd files on dvd and play them as a one movie file. I know that I can convert to different format and play them on dvd player but I think that it will be too complicated and time consuming
JKoniak -
Sounds like you are talking about a data dvd. Then you can merge the files with the programs mentioned, Filemerger or VideoReDo. (Though I have never tried the second one) This will likely not work on many players. Authoring to DVD format would make the video more standard.
But give it a try. If the player will work with just MPEG files, you may be OK. -
If you're doing a Video DVD, there's no point in joining before authoring, as that's done in the authoring stage (using TMPGEnc DVD Author)
/Mats -
If you have 2 SVCDs, then you can use SVCD2DVD. This will create 2 DVD compliant MPGs which you can use in your authoring program.
If the SCVDs are physically on 2 CDs. Then extract them as BIN files or use ISObuster to extract the raw MPGs.
I'm sure there guides on this site for SVCD2DVD
Hope this helps
ironballs -
Guys thx for your advices. I made everything like you said and everything is OK but I have one more problem to solve. I have 2 subtitles files what am I supposed to do to merge and synchronize them so that they run smoothly with this mpeg file which I merge before.
JKoniak -
What type are they? What's the file extension: subtitles.???Originally Posted by jarkoThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I have few movie files and different kind of subtitles: sub, txt, (idx?), srt.
Which type is the best and can I change one format to another?JKoniak -
Check out the various subtitle tools in the "Tools" section. Subtitle Workshop might be one worth looking at...
Carpe diem.
My movie files played on my standalone Mpeg-4, Divx, Svcd, Vcd player (Vsonic L 1030 ) but doesn't matter what format are my subtitle they don't work. When I play Dvd movie of course I see subtitles.
Can someone tell if there is possible to put merge movie file with subtitles to one file ?JKoniak -
Yes, permanent subs for mpeg1 (VCD), mpeg2 (SVCD or DVD) and AVI
Switchable subs for mpeg2 (SVCD in rare cases - not supported by many players) and DVD
/Mats -
Is there any chance to fix this problem ?
Can someone tell if there is any possible way to merge movie files with subtitle files to make it as a one file??JKoniak -
Like I said - for a DVD this is done during the authoring stage, becoming part of the VOB file(s). For "all" other formats they have to be rendered onto the video itself during encoding. Some AVI filters/players can add separate subtitles.
/Mats -
I want to join 2 svcd in one and I want to add subtitles but to make them playeble on my standalone Divx, Mpeg-4, Dvd, Svcd player I have to merge them together. Can someone tell if there is any possible way to merge movie files (svcd) with subtitle files to make it as a one file??
Thx for your response.JKoniak -
I thought we were past this: It's never necessary to join the source material before authoring as DVD. Easiest way to author a "2 source file", 1 movie DVD with subs, is to use DVD-Lab Pro
Create 2 movies. Have movie1 link to movie2, so that movie2 starts playing right after movie1 ends. (It's just one movie, but since it's in 2 parts, DVD-Lab will treat it as 2 movies)
Add the subs (.srt is easiest) for source file 1 to movie1, repeat for movie2.
Done.
/Mats -
Can you tell me how I can make permanent subs for mpeg1 , mpeg2 and AVI
files. what program I can use and where I can find some tutor how to do this ? Sorry, that I bother some much but I really want to know how to solve this problem.
Thx.JKoniak -
Search for "subtitles" in the guides section. I believe there's loads - one (or more) should match what you're after.
Carpe diem.
There's no standardized way to do this, that doesn't involve reencoding the video. In general terms:Originally Posted by jarko
Load the source video in a video editor (VirtualDub or AviSynth), add the subs with a filter. For AVI output, encode using VirtualDub, for mpeg output, frameserve to your fav mpeg encoder.
/Mats
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
join MZ TS files together
By dude905 in forum Blu-ray RippingReplies: 8Last Post: 3rd Apr 2011, 22:48 -
How can I join 2 sup files?
By EC in forum SubtitleReplies: 3Last Post: 25th Mar 2010, 12:51 -
2 movie files, 2 sub files. Need to join them into one
By andre477 in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 22:03 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
