Hi Baldrick / Anyone,
Is there an easy way of viewing a profile from scratch, that I'm missing?
Say I'm at the homepage (or anywhere else - not in a forum) and I want to view someone's profile. My current method is to do an advanced search for their name only and then click on the "Profile" button next to any one of their posts in any thread.
If there's an easier way, what is it? If there isn't, would you consider having some easy way of viewing someone's profile?
Ta, Daamon.
Results 1 to 10 of 10
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Short of searching for them I don't see how it could be faster, at some point your going to have to do a search. There's 90,000 registered users.
Hi thecoalman,
I was thinking of something along the lines of a dedicated "View Profile" field on an appropriate page / pages (say, the "Forum Index" page?) where you can type in the profile (wildcards accepted) and it'll return the exact and / or similar matches that can then be clicked on to view the profile.
As you say, still involving a search, but quicker / less "painful"...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
I can't speak for Baldrick but as a site owner I can tell you that would be occupying too much valuable space and wouldn't be justified for the amount of use it's going to get. There's very few people that are going to be searching for a specific user.
Yeah - I'm guilty of thinking from the user's perspective, not the site host's... Still - I figure it's always worth asking... I don't mind a "No" if it's reasonably justified.
This is where Baldrick comes in with: "No"
Carpe diem.
You could put
https://www.videohelp.com/forum/search.php?search_author=username
into your favorites, then change the username to whatever you need it to be. This is effectively the same as doing a forum search but might be a bit quicker.
Either that or visit
https://www.videohelp.com/forum/memberlist.php
and find the member.If in doubt, Google it. -
I just looked, the newest version of this board which is in bevelopement will support that feature.
@jimmalenko - The favourites idea is better - I hadn't thought of that, but is OK only if I know the full spelling.
Where's the link for the member list? I've double checked on the "Forum Index" (as the URL you posted would suggest) and can't see it there...
@thecoalman - Ah right - Is that available to anyone? What's the URL? Or do you have special privileges?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
https://www.videohelp.com/forum/memberlist.php not much help there, there's no way to search it.
The new version in developement is not here..... Doesn't have anything to do with videohelp unless Baldrick uses it when it becomes available.
http://area51.phpbb.com ....page is currently down. -
Thanks coalman...
Carpe diem.
RipBot264 Profiles?
By shagratt71 in forum Video ConversionReplies: 2Last Post: 13th Dec 2011, 06:00 -
XMediaRecode... Levels and Profiles?
By smackyourfupa in forum Video ConversionReplies: 3Last Post: 14th May 2011, 14:52 -
libavcodec x264 profiles
By Spearmint in forum ProgrammingReplies: 0Last Post: 2nd May 2011, 20:57 -
Ripbot's Audio profiles
By thezanny in forum Video ConversionReplies: 0Last Post: 18th Mar 2011, 20:51 -
Different Mpeg Profiles
By AndreL in forum EditingReplies: 2Last Post: 11th Jun 2007, 10:00
