Some vcd mpgs are giving me a problem - they are basically freezing up and forcing me to close the program and restart - in the log it says
Type: VCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
Now this and every other file that has done this plays fine in every player I have installe don my machine (Windows MEdia PLayer, DIVX Player, etc) so I know it isn't a codec issue. Is there something I am missing? Thanks - other than this problem it is a great program!
yes iam getting same problem, usually where the 2 mpegs joins it freezes happing a lot latly
although I am glad I am not the only one is there a solution out there? We cannot be the only 2 having this problem. Perhaps editing something in the mpg with help?
Can you post or email me your log file please.
This MAY help!
Does the file name contain "&" ?
For example if i use filename "Life & Songs" I get :
Type: SVCD
Horizontal Res: 0
Standard: PAL
Audio SampleRate: 0
However, with filename "Life and Songs" I get :
Type: SVCD
Horizontal Res: 352
Standard: PAL
Audio SampleRate: 48000
What browser are you using these days?
By johns0 in forum PollsReplies: 60Last Post: 28th Aug 2012, 20:30 -
are the days of the cpu numbered?
By deadrats in forum ComputerReplies: 13Last Post: 1st Jul 2009, 02:19 -
How bad is U3 these days?
By ahhaa in forum ComputerReplies: 14Last Post: 22nd Aug 2008, 02:52 -
The PC's last days?
By Jo The Veteran in forum ComputerReplies: 8Last Post: 11th Sep 2007, 07:44 -
DVD playing for 4 days!
By Kargo in forum DVD & Blu-ray PlayersReplies: 4Last Post: 27th Jun 2007, 01:55
