I was thinking to capture with PowerVCR mpeg2, PAL DVD format 352X576 and then use PVAstrumento to fix possible sync problems as indicated in the http://www.digitalfaq.com/capture/nonatimpeg/nonatimpeg.htm
Do you think is ok?
Any ideas about PowerVCRs settings? (I used bitrate 5000, B frame 2, P frame 4)
My problem is that trying to record a message is coming out saying
“S0028 : Unable to run caprure graph” while with other resolutions (352X288 etc) its working ok
Hi,
I capture with 352x240 regularly and for a long time I used my own program to correct the sync, but recently I found that the VideoRedo editor ( http://www.videoredo.com ) will automatically correct the sync from PowerVCR if you edit or run their streamfix program. It's a very nice editor with cusomizable buttons. I've used 1K, 3K and 4K bit rates with 1-2-4 IBP.
-infotech -
It's an O.K. solution.
I have switched to mainconcept 1.4.2. I prefer the results.La Linea by Osvaldo Cavandoli
Thank you all for replying. (Eyxaristw file)
But I still do not know what to do to stop taking the message “S0028 : Unable to run caprure graph” whan I m using 357X576 resolution with PowerVCR
Or just ignore this resolution and use 352X288? But isnt this giving poor results ?
Thnks aganin in advanceKONX OM PANX -
You need to hack the registry of power vcr so be able to use 352 x 576. There are guides to do this, also visit the www.digitalfaq.com
Min asxolise me malakies. Bres to mainconcept kai kane tin douleia sou me auto. Spastiria af8ona sto diadiktyo. Ola ta alla programata, eina trixes!La Linea by Osvaldo Cavandoli
But I have already hacked the registry! The program is just saying the message I was telling above...What the hells is the problem?
About mainconcept I ve already installed it. Thank you. You say that I should forget PVCR and the rest. Ok I will try it! No synk problems with it?KONX OM PANX -
No synch problems with mainconcept. Audio / Video always match perfect.
Can you tell me about the settings for capturing from VHS to mpeg for DVD os SVCD with mainconcept?
KONX OM PANX
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Powervcr II 3.0 Deluxe
By vijaye05 in forum Capturing and VCRReplies: 1Last Post: 7th Oct 2008, 05:30 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
