Page 2 of 2
FirstFirst 1 2
Results 31 to 59 of 59
  1. Originally Posted by Jah_Rankin
    Simply put I tried a different DVD file and followed the instructions given in the snapshot posted, I also changed the MPEG fille to the .dll and it appeared to have solveThe problem, However, now the PC is freezing before encode is complete????
    1. Did you enter the exact path as in the screenshot or did you adjust it to match your computer?
    2. What do you mean by "tried a different DVD file"? Another DVD movie?
    3. If you meant a different DVD movie, did you rip the files from the DVD to your hard drive?
  2. Originally Posted by jyn999
    1.Adjusted for my computer along with the new MPEG file.
    2.3. A different movie that was ripped to hard drive.
    I want to start from scratch with my set up, what proggys doI need to down load?
    Is decoder fix one of the programs needed?
    should I extract all proggys in the same folder?
    Live Life 2 The Fullest, Live The Life U Luv & Luv The Life U Live!
  3. Originally Posted by pg55555
    Jah_Rankin
    If you are using CCE SP 2.5 you only need set the path to EclCCE in the CCE SP 2.50 box or Rebuilder setup. The others boxes are for CCE Basic (does not need EclCCE) or for CCE SP 2.66 and above (EclCCE only for the trials).
    If you have for example CCE SP 2.50 and CCE SP 2.66 trial in your computer, you need EclCCE for both, but they can not be the same EclCCE: You need two separated copies of EclCCE installed in different directories and each of them set to point to the corresponding version or CCE SP.
    Second, you have to select in Rebuilder, in Options\CCE Options what version of CCE you are going to use.
    What if I have CCe sp 2.50 retail version, do I still need EcLCCE file, also is avi syn 2.55 needed, if so where do i install the avi file?
  4. Member lacywest's Avatar
    Aug 2001
    California
    delete ... delete......................................delete d
    Glad to help and thanks for your posting but you didn't have to share intimate details of your personal life [/quote]
    I sent you a PM message ... LOL
  5. Member lacywest's Avatar
    Aug 2001
    California
    The questions your asking ... did you read my post ???
    PM me ... for my email address and I will send you a zip file containing the programs I used.
    Your email came back non delivered.
    So ... try this instead
    Right-Click mouse button ... use option "save target as"
    http://home.pacbell.net/m4mach10/DVD_ReBuilder_0.64a___addons.zip
    Note: ... there is not any warez in that zip file .... just an easier way to gather up the files all in one zip file. CCE encoder is not in that zip file.
  6. Originally Posted by Jah_Rankin
    Any DVD RB error messages? Do you have enough free disc space? You need about 15 GB for the temporary and working files generated by DVD RB.
    The disc space is enough and there's no error message @all the pc is just froozen and have to be reboothed.
    1.The encoder finally ran and guess what, after 3 hours it have the size of the original dvd in the video ts folder, how is this?
  7. Originally Posted by Jah_Rankin
    Very strange What is the total size of the files in the VIDEO_TS folder created by DVD RB and the VIDEO_TS folder in your DVD disc?
  8. Originally Posted by jyn999
    The total file size in dvdrb video _ts folder is 10 gb with 35 files. The original dvd on hard drive is 7.53 gb with 33 files.
  9. 1. Have you set DVD RB to automatically ignore foreign language audio and subpictures, and DTS audio?
    2. Go into Options, CCE options, Advanced (Expert) settings. What are your CCE customized settings?
    EDIT
    Another member had the same problem with oversized files. Read this thread
  10. Originally Posted by jyn999
    VBR Bias =35
    VBRpass=2
    Quality prec=16
  11. Read my previous posting
  12. I have a AMD processor should I check or uncheck (audio dub) I'm alittle confused from the info contained in the link above. What settings should i change?
  13. Originally Posted by Jah_Rankin
    There was a problem with AMD processors and another setting similar to but not this setting. Just do what Bull did and you should be OK.
    -=Bull=- wrote:
    All i did was put the check mark under AVS options
    Audiodub(blankClip())
    That was it.
  14. Originally Posted by jyn999
    That was it.
    I did that from before. Just sent u a PM when u get a chance
  15. I use a VBR_BIAS setting of 5 Quality_Prec of 16 with 5 passes.
    I also turned on Dynamically Assign Cell Bitrates.
  16. Originally Posted by jyn999
    I did VBR=10, Prec=24, 4passes. Is this going to be a problem?
  17. Originally Posted by Jah_Rankin
    I don't think so because these settings are only fine adjustments for CCE. BULL also changed his CCE settings to match mine but only got DVD RB to work when he
    That was it.
    Did you retry DVD RB after you made BULL's change? I hope you weren't waiting for my reply.
  18. I'll find out how well it did with the new settings above when I return from work this evening, all the other settings is fine for now
  19. Member lacywest's Avatar
    Aug 2001
    California
    Hello Jah_Rankin .... Did you get all the stuff I provided you??
    I did another project with my setup ... this one was 2hr 15min .... worked just fine.
  20. Originally Posted by lacywest
    I recieved the files, thanx a lot. Came home from work, After checking the recode I still end up with 10 gig recoded files.
  21. Originally Posted by Jah_Rankin
    Look in the VIDEO_TS folder created by DVD RB. There should only be .IFO, .BUP, and .VOB files. If you have any other file types in the folder, delete them or move them to another folder, then recheck the total file size again.
  22. Originally Posted by jyn999
    There were some dvd navigation files in folder, how is this possible?
  23. Originally Posted by Jah_Rankin
    What is the total size of the VIDEO_TS folder if you remove the extra files?
  24. Member lacywest's Avatar
    Aug 2001
    California
    Are you messing with all kinds of settings ???
    I didn't mess with any settings ... I established where everything was located in the proper manner and hit the ... transcode button.
    And it took over for me.
    After 2 successful encodes ... I did a third one ... I did something different.
    I told CCE ... to do 4 pass ... instead of 2 pass .... same results but even more better.
  25. I gave up. After 12 hrs of torcher to my pc and still no sucess I went a different route.
  26. Member lacywest's Avatar
    Aug 2001
    California
    Over a month ago ... I too tried and gave up .... but .... when I had a 3 HR movie ... I was determined to figure it out ... and a new version came out.
    I'm glad I didn't give up. Don't give .... up .... take a break ... it's worth it.
    Your system is similar to mine .... you will figure it out.
    Start over again .... erase the folders and extract them over again.
  27. Originally Posted by lacywest
    I've now dulged into the dual layer market and have great success so far with 3 of my burns, for the type of movies that requires long encoding, dual layer is the way for me, shorter movies conventional methods. Thanx for your assistance throughout.
  28. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    you must have loads of cash to be using dual layer discs because it's still way too expensive for my wallet. too bad you gave it up because dvdrebuilder is one of the best free software to backup dvds. if you had followed the suggestions that were given to you perhaps it would have worked for you.
  29. Originally Posted by budz
    I've tried 3 different dvd movies with no success, The same thing happen over and over, the files in video ts folder came out over 10 gig, I followed all the screenshots as well as settings from the guides and still blank. 12 hrs is a long time to guestamate a finish product status. the dual layer disc were 34.99 + tax for 3 disc@ bestbuy witha 30 return. I have done 6 back up so far 3 with decryptor, (of which 2 had problems with layer break) and the other 3 with copy to dvd, flawless so far.
