Does anyone know how to convert a sequence of BMP images directly to MPEG2. I tried doing it through Ulead Media Studio frameserving to TMPGEnc. However, this causes noticable image quality loss. Ideally I would like a program a program to encode the image sequence directly to MPEG2 for DVD unless someone has any better ideas.
Any help would be appreciated, thanks.
Results 1 to 13 of 13
Hi stalker11,
You could use Slide Show Movie Maker to make an AVI from your bitmaps and then encode that to an MPEG. The tool is free and also does fades and transitions which a "direct to MPEG" tool might not do.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
you can:
use tmpgenc
use procoder 2
use vegas
use CCE
load the bmp's into avisynth or virtualdubmod and frame serve them to everything else ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the help. I tried the first suggestion posted, however, QuEnc didn't offer me the features I wanted; plus I am more familiar with TMPGEnc. However, I did get AviSynth and I frameserved from Ulead Media Studio using Ulead's image sequence format. AviWrapper seems to have some encoding artifacts when frameserving through it, it looks much better through Synth. This was probably the easiest way for me to do it, I don't really want to be messing around with Virtualdub's frameserving right now anyway, I've used Virtualdub much before, but never for frameserving.
Thanks for the help, I must salute the members of this forum, you guys have good response time... keep it up. -
use tmpgenc or tmpgenc plus and under Option-> Environmental setting-> General, check the box for "Open sequence files as a movie". Open the first bmp and all will be opened automatically.
all the bmps must be in the same directory also ..
and named sequentially
example:
and so forth"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
BJ_M -
quick question - when importing into Vegas, how would you go about setting the image duration?
I have a sequence of 129 frames, and I want them to last about 6-7 seconds each. I import the sequence into Vegas 4, and it gives me about a 3 second video file.
I CTRL-drag the end of the sequence in the timeline, but it will only allow me to drag it out to about 20 seconds or so.
Is there any way to globally set the duration of each image? is there a trick I'm missing?- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
in options you can do this - set time of each image ... PLUS do not import as a image seq as that is same as a video file (1 frame per frame 1/30 sec)
import as a bunch of stills (do NOT check off import image seq.) ... these dont need to be numbered in seq either ...."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
thanks for the info - if I import a bunch of stills, without checking off "import image seq" what order will they appear in?Originally Posted by BJ_M
if they are a numbered sequence, will they propagate the video timeline in numeric order, or will I have to shuffle them around?- housepig
Housepig Records
out now:
BJ_M -
thanks for your help - got it figured out.- housepig
Housepig Records
out now:
glad to be of service
(send cash or MO - not a check)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 15Last Post: 12th Apr 2013, 09:37 -
Converting .MTS to a .JPG image sequence?
By Anon1 in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2011, 22:14 -
CLI batch Vdub Image Sequence
By corsiva in forum Newbie / General discussionsReplies: 0Last Post: 8th Mar 2011, 13:49 -
best compression for image sequence movie ??
By mehdi0016 in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2007, 10:17 -
Image sequence to HD 1080 DVD? Lots of questions, please help!
By rayrayray in forum Video ConversionReplies: 5Last Post: 27th Jul 2007, 13:43
