hi,
I use VirtualDubMod for compressing (DivX 5.2.1 codec) my avi-files captured by my DigiCam. When I look the compressed avi-files on my PC, it looks very fine and it is alright.
But when I look the same file on my TV (PAL) with my Philips DVD player 720SA (DivX certified), the film runs to fast.
Moreover, the audio is not synchronized and nobody can understand the audio.
Any idea which settings I have to change?
goana
Sounds like you have a PAL DVD player and TV, and an NTSC video...
What's your frame rate?
"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
hi,
the avi-video has 320x240 and 15.000 fps.
The settings at VirtualDubMod are set to default (15.000 fps). I am working with "full processing mode".
It is also a little bit strange, because when I play the uncompressed video on my TV directly from my camera (via cable) then it is perfect....
I think I have to change any parameters at VirtualDubMod but which one?
Any idea?
goana -
hi,
I have made changes in the settings of VirtualDubMod:
Source rate adjustment: Change to 25.000 frames per second or
Frame rate conversion: Convert to 25.000. frames per second
As a result, the compressed video runs still to fast in both cases (it seems that the video runs a little bit slower). Moreover, the audio is not synchronized (in both cases!
Any idea how it works?
goana [/img]
How to Fast Forward an AVI Watching it on TV?
By gonwk in forum Newbie / General discussionsReplies: 7Last Post: 27th Jul 2009, 11:10 -
converted AVI to VCD, but playback is too fast
By LWC in forum Authoring (VCD/SVCD)Replies: 4Last Post: 21st Nov 2008, 21:55 -
.MTS to .avi conversion (video seems fast)
By puncho in forum Video ConversionReplies: 9Last Post: 12th Sep 2008, 01:49 -
DVD- AVI: Video too fast
By HHBear in forum DVD RippingReplies: 1Last Post: 14th Jul 2008, 19:41 -
Fast converter for AVI to WMV???
By darren.Hall in forum ffmpegX general discussionReplies: 0Last Post: 3rd Dec 2007, 11:21
