ok, problem! I have alot of .avi files, 2 season of simpsons and basically, when i load them into xpress it says,
.......avi can not be open or unsupported......
i have installed every plugin known to name yet i am so confused!!!
any ideas?
hi,
it says that i have all the correct codecs installed. its a DIVx 3 codec used, and audio is 48000Hz 160 kb/s total (2 chnls) -
have you looked at https://www.videohelp.com/tmpgenc.htm#problems ?
If in doubt, Google it. -
You probably need the Divx 3.11 codec:
http://www.divx-digest.com/software/divxcodec.html
need help importing MKV files into Tmpgenc Xpress 4 under Win7 x64 please
By BilboFett in forum Video ConversionReplies: 6Last Post: 23rd Feb 2011, 01:37 -
PROBLEM: AVI -> MPG by using TMPGEnc 4.0 XPRess (4.2.3.193)
By Hummelchen in forum Video ConversionReplies: 0Last Post: 14th Jun 2010, 06:10 -
TMPGenc 4.0 Xpress can't encode AVI with 16:9 display
By Sanderverbeke in forum DVD RippingReplies: 2Last Post: 23rd May 2010, 07:21 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
TMPGenc Xpress 4/VobSub cannot load .avi with subs
By varu in forum SubtitleReplies: 3Last Post: 14th May 2007, 18:26
