The more I read on this, the more conflicting information I absorb, so I'd like a bit of help here:
When rendering:
Profile and Level: These are set at Main Profile and Main Level
Would I want to change these to High because I captured 4:2:2 with Huffy?
The sampling format is grayed out at 4:2:0 because of the profile settings. If I capture at 4:2:2 wouldn't I want to match that number?
Is the default I frames 15 B frames 2 a good setting?
DC coefficient: This is default at 9. Main concept states that raising this to 10 (max) is for low motion video (therefore degrading quality) - I was under the assumption that a higher value of the DC coeffiecient would produce better video.
Don't get me wrong, I have produced some excellent encodes from my AVI caps, but I was looking to push the envelope so to speak, by tweaking.
Thanks in advance.
no - not for DVD
the default is fine for NTSCIs the default I frames 15 B frames 2 a good setting?
for DC , 9 is a good choice for most dvd's at med bit rate , if very high detail or max bit rate is used, 10 would be better ...
using 10 at <6000 bit rate is not a great idea ...
using 8 even at very low bit rate is sometimes a good idea .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks much BJ_M. I guess what I'm getting is the best Vegas can output.
a clean source is the best thing you can do to improve encoding quality -- in vegas, if you have a noise infested clip , using the median filter works well ..
Source is very good. Laserdisc. I am very happy with the encodes, but occasionally I find that motion has an artificial look to it. It's very faint, but I see it. I may be looking for a perfection level that dosen't exist within the MainConcept encoder.
I'm not sure what you mean by artificial look? If the motion is jittery on your TV (but not on your monitor) then the field order is wrong. That wouldn't be very faint however, so I assume that's not the problem. Just trying to make sure that you're aware of this field order stuff.
I understand interlace (a bit) and no, it's not that! It's hard to explain, not jitttery motion but not 100% smooth either. Not on all scenes, jut the high motion ones. And not always either. This happens if I encode Upper Field First, Lower Field First or Progressive. My TV is a 1982 Radio Shack model and I am currently using my XBOX as a DVD player as my Panasonic finally gave out on me. Maybe it's that hardware combo? I was telling LordSmurf that I really need to go back and look at my source. These are films from the 40's and 50's and I never stopped to just WATCH the laser. There may not be a problem with the encoder.
Must i convert High@5.1 to Main@L4.0 , how and what settings ?
By G30 in forum Video ConversionReplies: 6Last Post: 25th Apr 2012, 13:18 -
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 20:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 7th Aug 2010, 00:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 17:19 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 16:22
