Does anyone know the encoding method used for the XVCD sample on this webserver, i.e. what programs and what settings?
Thanks,
Blaine
BxB,
First, you have to show us the name of the file you downloaded. We are not
mind readers! There's like 8 links (in the tools section ) to download some
sample clips and ranging from VCD to xSVCD.
Provide us with the link (or text unerlined in link) so we can see what you
are talking about, OR the owner of THAT clip might be reading your post
and will be able to help there!
K?
Well actually there are only two XVCD samples, NTSC and PAL.
The one I'm specifically asking about is NTSC, http://www.dvd-wizards.com/vcdhelp/XVCD-NTSC-2500kbit-352x240.zip.
Thanks,
BB
Premiere and sample rates
By tpapictures in forum EditingReplies: 6Last Post: 4th Apr 2011, 20:05 -
white balance-sample
By kzeko in forum RestorationReplies: 20Last Post: 22nd Oct 2009, 19:06 -
[SOLVED!] Converting Variable Sample Rate to Constant Sample Rate
By Midzuki in forum AudioReplies: 17Last Post: 24th May 2009, 10:26 -
Where can I find 720p50 sample?
By johdeck in forum DVB / IPTVReplies: 2Last Post: 27th Nov 2007, 20:45 -
NeroVision 3 Sample format?
By LiBiDoXP in forum Video ConversionReplies: 0Last Post: 1st Jul 2007, 12:50
