I have this XVID encoded movie( Ac3 audio)
CD1 800mb
CD2 800mb
To burn it on cd i ve to cut the movie...
I can successfully cut cd1 but cd 2 give me an error
"Invalid floating point operation"
No problem playing the file..
am using easy video splitter to do the cutting....
hxxp://doeasier.org/splitter/
This is a good tool and I ve used it many times successfully...
I ve tried virtual dub as well and it gives me error too... Looks like the problem is with the encoding of the movie.....I dun know....
Any one knows how to fix this file....I am a noobie
Thanx a lot
You got itOriginally Posted by amitkr
Go to the guides on your left and find one on how to remove corrupt frames from divx/xvid movies. There are several to choose from.
a disk error occurred during a write operation
By SE14man in forum ComputerReplies: 8Last Post: 8th Nov 2011, 01:16 -
Help - invalid Floating point operation!!!!
By Pintocas in forum AudioReplies: 1Last Post: 15th Sep 2010, 09:28 -
r6002 floating point error with MPC , maybe
By BWMagus in forum Software PlayingReplies: 5Last Post: 19th Mar 2009, 08:08 -
MPC Runtime Error, 6002 floating point support not loaded.
By Leo99 in forum Software PlayingReplies: 5Last Post: 24th Nov 2008, 02:22 -
VirtualDub invalid handle error
By 2manytapes in forum DVD RippingReplies: 0Last Post: 17th Mar 2008, 12:37
