I'm converting VCDs to DVD and noticed that VCD contains two different languages and would like to keep both of it.
I use TMPGEnc Plus convert the original VCDs to DVD format MPEG2 & 48KHz, then when I use TMPGEnc DVD Author to convert it with the Option "Bilingual Dual Channel", I will have no sound in the final format. I was able to play it with sound in computer, but not on DVD player.
Is there anyway I can convert the audio to 2 channel from the DVD converted files?
Thank you for your time.
Results 1 to 1 of 1
Changing the language designation of subtitle & audio tracks
By DeathStalker77 in forum SubtitleReplies: 6Last Post: 8th Aug 2010, 22:32 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
DVD ARchitect 5.0 Right to left language support
By Andonyx in forum SubtitleReplies: 0Last Post: 20th Sep 2009, 15:53 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
DVD Language Question
By nin28 in forum DVD RippingReplies: 9Last Post: 19th Nov 2008, 22:15
