When a person backs up a DVD with AC3 5.1 surround sound onto the computer, do they have an option to keep that 5.1 surround sound? I have tried this and I got a 5.1 AC3 file. If I burn that onto a DVD-R, is it possible for the background sound (not the voices for the Center speaker) to lower itself for some reason? I think that's the case with this one I'm doing for some reason.Why is that?
Unless you have processed the AC3 file seperately, it should not be affected. Most copy software works by manipulating the video bitrate, and leave the audio alone. You have the option of dropping certain tracks, but not transcoding it.
What software/copy method did you use ?
What are you playing back on ?
Is it the same on other playback devices ?Read my blog here.
I forgot what I used since it was a long time ago. I brought this up again because I was wondering. Are you into anime (hence your name Gunslinger from Gunslinger Girl?). If you are, I might have more specific question0s on this issue for you in PM.
I only have 2 DVD players, one is connected to the Dolby Digital while the other isn't. The background sound is low while the other sounds are all normal on the DVD player with DD. I haven't tested it on the other player because why bother? I don't have a computer 5.1 setup but I listened to it on the computer anyway and the background sound is definitely louder than the voices. So why is it that it lowers itself? It's just that one, I have had no problems with other AC3 5.1. -
Wait! Would Dynamic Range Control make the music softer?
I already tried to set my AMP to the three options for DRC but they all sound the same.
Ac3 Downsampling problems
By robbynaish in forum AudioReplies: 1Last Post: 27th Jan 2010, 18:33 -
downsampling MKV
By saimike in forum EditingReplies: 1Last Post: 6th May 2009, 13:08 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 11:24 -
Downsampling H.264 and splitting
By alfista in forum Newbie / General discussionsReplies: 0Last Post: 2nd Aug 2007, 07:55
