Okay I burnt a dvd using clonedvd and everything seemed to go fine, ne errors or anything. It plays back fine in my dvd-burner and in my parents computers dvd drive but when I put it in the standalone dvd player it plays the first track and about 20-30 seconds of the second track and then stops. It wont start playing the disc again unless the tray is opened first. I dont know what could be wrong 'cause it works perfectly in the comps. Please help.
Well, according to VH's database, your standalone DVD player doesn't support DVD-R/+R meaning that burnt DVDs will seldom play in it. This is most likely the problem you're having, assuming that the standalone DVD player in your profile is the one you're attempting to play the burnt DVDs on. If you're using a different standalone that should be capable of reading burnt DVDs, you're most likely using bad media and should check out other brands.
I only dream in black & white...
MSN: paschendale@gmail.com
playback problem
By winston879 in forum Software PlayingReplies: 2Last Post: 14th Mar 2011, 15:33 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Color Playback Problem?
By magikalfly in forum Video ConversionReplies: 7Last Post: 19th Feb 2009, 00:14 -
AAC 5.1 playback problem
By TigerShark in forum AudioReplies: 0Last Post: 30th Sep 2007, 11:08 -
playback problem
By stigslim in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Aug 2007, 18:19
