I'm capturing VHS footage in DV and then rendering to mpg-2 and wmv for the web.
I'm doing this in Vegas 4 (I've had no reason to upgrade yet, don't know if this would be it).
Most of the footage is ok. Second-fourth generation for most I'd say. I always have some crap on the bottom in the overrun area.
What's the easiest way to mask this for my wmvs? Is it as simple as making a transparent image with a certain size border (if so - what's the safe border size)?
One other semi-related question: when I burn these to dvd, they look fine on my tv (I just have a normal tv) - do hdtvs or flat screens see more picture/overrun area? Should I consider doing this to my mpeg-2s as well?
There is a Generated Media filter in the F/X tab in vegas that is a border. Drag it on the timeline and adjust it as needed.
Although, IMHO, this is just a waste of encoding time as the overscan area you are objecting to will not be visable as you have stated. -
I'd just like to do it for the wmvs I post on the web, because it is visible there.
Thanks for you help. -
you mean then you want to crop it ... use the pan and crop
Originally Posted by BJ_M
So does anyone know about my other newbie question: is there less overscan on an hdtv or flatscreen? -
different models have different amounts ... my video projector has almost none , and my hdtv monitor maybe has 3 or 4 % (i have not checked exactly because I really don't care - as it doesnt mater) ....
if you realize how movies are shot -- and i do -- you would understand anything in the upper 25% and in the borders up to 10% dont mater anyway ... the director genenerally never looks there , or anyone else ..
and in a theater --- most of the time 2-5% (sometimes more) is masked off also , just like your tv .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Hi BJ_M,
Thanks, that's good to know. I am generally working with sports clips however, and just looking to product clean looking segments with no distortion from the old VHS tapes.
Overlay/Mask/Layer Question
By legocrazy1 in forum EditingReplies: 3Last Post: 16th Jul 2010, 04:00 -
Add Audio to video not working in VEGAS
By beavereater in forum EditingReplies: 1Last Post: 16th Apr 2009, 12:07 -
how to increase/decrease and move a mask on a clip around(sony vegas)
By bojadada in forum EditingReplies: 4Last Post: 22nd Oct 2008, 22:38 -
From RGBA to mask avi
By fapo in forum Video ConversionReplies: 0Last Post: 2nd Jul 2008, 10:00 -
Vegas - add image to video (DVD(mpg)) and moving image around
By psxiso in forum EditingReplies: 4Last Post: 11th Jul 2007, 04:29
