Hello,
I capture TV programs using a ATI TV Wonder pro on a Windows XP computer. At DVD quality, it produces 720x480 (NTSC) 48khz mpeg files. Then I copy this mpeg file over to my Linux computer. Now, on Linux, I want to create a dvd. I use dvdauthor. First, I try something very simple, a dvd without menu. So I only tell dvdauthor to create a dvd with the mpeg file previously captured. It creates the dvd structure. Then, when I watch the dvd with xine, it works. When I use totem, I'm getting the sound but no image. I also tried on windows with PowerDVD, I'm getting the cound wihtout image. What am I missing. I looks like the captured mpeg as something wrong?
Thanks,
David.
Watch the output in the terminal window. Look for the status of mplex to make sure it doesn't detect anything funky with your mpeg. Mplex may flag your stream wrong. PAL when it's NTSC, so on. Make sure your sources are correctly defined in your xml.
You could try Q DVD Author, puts a nice GUI on DVDAuthor. DVDStyler is another option, though I haven't tested this one out yet. -
What do you mean my sources are correctly defined in my xml? mplex says mpeg-2 720x480 NTSC, mplex isn't complaining about my mpeg...
I used avidemux2 to save the mpeg file as an mpeg "DVD PS" and now my dvd works!
I'll make more tests tonight but it looks like the problem is solved.
Thanks,
David.
Captured VHS to DVD didn't turn out so well...
By snafubaby in forum Capturing and VCRReplies: 3Last Post: 24th Dec 2010, 07:20 -
Fastest from captured video to dvd?
By larrym in forum Newbie / General discussionsReplies: 35Last Post: 14th Jul 2008, 07:03 -
Mpeg 2 video captured via Beyond TV play back question.
By Lothar1974 in forum Capturing and VCRReplies: 1Last Post: 25th Oct 2007, 17:33 -
captured mpeg vid plays nicely, but....
By snafubaby in forum Authoring (DVD)Replies: 5Last Post: 23rd Sep 2007, 17:45 -
Captured dvb-s dvb-t mpeg video to DVD
By tonut in forum Authoring (DVD)Replies: 6Last Post: 7th Sep 2007, 07:02
