Ok so i just been trying to convert my bin files as usual when i notice the program stuck on one step doing nothing so i stopped the program and i check the logs and this is what they said. Hopefully someone can enlighten me to what is wrong thank u
Analysing File: D:\temp\svcfodler\metallicaa.mpg
C:\Program Files\Badgersoft\SVCD2DVD\vcdxminfo.exe: *** shared version mismatch detected - 0x75BE006C/0x18A2005A.
You have multiple copies of cygwin1.dll on your system.
Search for cygwin1.dll using the Windows Start->Find/Search facility
and delete all but the most recent version. The most recent version *should*
reside in x:\cygwin\bin, where 'x' is the drive on which you have
installed the cygwin distribution.
Error getting mpeg details. (probably due to AC-3 audio)
System.IO.FileNotFoundException: Could not find file "D:\temp\svcfodler\metallicaa_info.xml".
File name: "D:\temp\svcfodler\metallicaa_info.xml"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReader.CreateScanner()
at System.Xml.XmlTextReader.Init()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
Analysing File: D:\temp\svcfodler\metallicab.mpg
Results 1 to 1 of 1
Converting xvid movies
By SJRSMITH1 in forum DVD RippingReplies: 1Last Post: 14th Jul 2011, 00:26 -
Converting movies to DVD
By violator666 in forum Authoring (DVD)Replies: 14Last Post: 21st Mar 2010, 04:57 -
Converting .mpg movies
By baysee in forum MacReplies: 14Last Post: 25th Sep 2009, 07:11 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 19:10 -
how can I Converting movies to psp
By rreyes3000 in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2008, 12:08
