I did a search but couldn't really find the answer so hopefully someone might have an answer. When I do a capture the resluting file is saved as a BMP and I couldn't find anywhere in the setup to be able to save as a JPG. Is there a option I am missing or it just can't be done?
Thanks in advance for any help.
Results 1 to 10 of 10
Click on the middle bottom button and you can switch from bmp to jpeg.
Thanks Bodyslide for the quick reply but I guess I may have to look at a newer version as mine doesn't have this fearture.. I am at work at the moment but from memory I think I have Ver.4.
Thanks again -
Just downloaded v6 trial version and will take the upgrade.
Thanks again for your help. -
Well, that doesn't actually convert it though, does it? One simple way of converting, however, is to open a .BMP in Paint, then Save As a .JPG.Originally Posted by ButchX
p_l.. Started doing that but was looking for something less time consuming
Guess I take too many captures....
I'm sure if you go to http://www.download.com/, you can find some kind of batch conversion utility, for example among these.
A lot of people like IrfanView, and it's free.
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 08:42 -
Plextor M402U - Capture Device not recognised (WINDVD and Nero)
By phantomwalker in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2008, 21:52 -
WinDVD 9 vs. PowerDVD 8?
By Vrex in forum Software PlayingReplies: 0Last Post: 7th Apr 2008, 22:54 -
WinDVD creator 2 won't allow dvd
By CullenJ in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2008, 20:57 -
WinDVD Creator 2 - Subtitles Disappear
By scooter1203 in forum SubtitleReplies: 2Last Post: 11th Oct 2007, 07:39
