Does anyone know how to remove the macrovision protection from my Mustek r100a? Also, I do not seem to be able to get clear sound when I search for channels with the DVDRW, except the digital channels. Is there a known issue with sound concerning the Mustek? I did whatever the manual says but I can only get sound and b/w picture from the scart source, which is not too good cause I have to change from Scart 1 to Scart 2 whenever I want to watch whatever I recorded in colour. I would appreciate any info. Thanx in advance.
I can't help you with the second part, but to remove macrovision you need to put a timebase corrector or similar removal device between your source and the Mustek's inputs.
You might want to read other user comments. Go to DVD Writers on the left of the screen under "Lists" and search for the model number under "Only Desktop DVD Recorders".
Firmware for Mustek DVD Recorder R100A
By Spot.Zwei in forum DVD & Blu-ray RecordersReplies: 3Last Post: 19th Jan 2011, 10:49 -
Code Free for Mustek Yukai MP76A
By eagle1200 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Sep 2008, 12:14 -
mustek yukai mp76A problem multi zone
By mustek in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Jun 2008, 21:47 -
Mustek R100A just died!
By mcgeechan6600 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Oct 2007, 10:14 -
Mustek V56L-5E DVD player How To Reboot remove YUV P-Scan setting
By ImNoSmarterN5thGrdr in forum DVD & Blu-ray PlayersReplies: 1Last Post: 8th Aug 2007, 09:32
