hey everybody,
i am in dire need to edit an audio file of mine which is an .mp3. i need to shorten its length, and since i am used to using Windows Movie Maker to edit my audios, i need to first convert the file to either WMA or WAV. so if anybody can post anything relevant at all that would be greatly appreciated. also if anybody has another shortcut way to achieve what i need to achieve, please feel free to post. ALL POSTS ARE WELCOME. so please dont hesitate. thanx to all.
-skip2mylou
Results 1 to 10 of 10
Wow! You got shocks, pegs... LUCKY!
there's literally hundreds of programs to encode from mp3 to wave And from wav to mp3
member since 1843 -
Hi skip2mylou,
Check out the "Audio Editors" in the "Tools" section - the top 3 in the list (click the link) are free and can cut MP3.
So, no need to change format - which is better for quality and time saving.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
There are hundreds of programs. Many of them are free, or are bundled with other packages (CD-Burning, video, etc), you may already have one.
GOLDWAVE is my preferred audio editor. It will open MP3, WAV, WMA, AVI and output WAV or MP3 or other formats (see website http://www.goldwave.com for details -download the Lame MP3 encoder to output mp3). It is shareware, you can try it free, and it is not expensive ($45).
I have been using it for many years for audio work (LP, VHS, 8-Track etc -> CD). I tried and bought other programs, but goldwave does everything I need for audio work. Fast and easy to work with (tip - set the temporary storage to ram to speed editing - since does not need to read/write to disk, but can work from hard disk if audio file bigger than available ram). -
This maybe off topic, but I don't know how to phrase it in a new post. So, here is goes...
I have a large mp3 (75mins) to burn into an audio CD by using roxio v6. I always want to split this big file into small track (perhaps 5 mins per track), so I can direct to different place from time to time.
I used Goldwave to split them before and it is time consuming. Is there a burning software, like Roxio or NTI, that will burn and put markers in at the same time, so I don't have to do it?
Thanks... ( I am sure many people have the same question as I, but did not know how to ask it) -
Donadagohvi (Cherokee for "Until we meet again")
tienquang2
Is the time consuming part for Goldwave the conversion from MP3 and the re-saving as WAV?
I have always found Goldwave to be one of the better tools for splitting. I will typically record the side of an LP in Goldwave, and then use cue points to split. Shift-Q to drop a que at the current location (so can do visually from timeline), or the Cue tool to manually enter them for time, or to use the silence detection in Autocue (Mark Silence), or to auto-insert cues at fixed time intervals in Autocue (Spacing).
There are many options - I use the Drop cue to time the cue/split points just where I want them. Then the split file (on CD Boundries) plits & saves as waves the separate tracks with autonumbering. When I burn then to CD with no gap between tracks it plays seamlessly as if the LP, But I can jump to each track. It goes pretty quickly for me.
Since I am going the other way, I then batch convert the split files to MP3s, so that I have MP3s of each track.
I was just wondering, since you found the Goldwave prcess time consuming?
To answer your question - I have not looked to see in the different burning software, as I have not needed it. I also had some poor experiences burning CDs directly from MP3s - for a variety of reasons - and so prefer to keep the audio and CD processes with their respective tools.
Convert expired WMA to MP3
By pchan in forum AudioReplies: 4Last Post: 20th Jul 2011, 09:44 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 05:02 -
Convert MP3 -> WAV, Copy to HD and RIP
By ctdvd in forum AudioReplies: 4Last Post: 23rd Jan 2010, 06:32 -
Is it possible to convert Mp3 to wma?
By t_jay17 in forum AudioReplies: 8Last Post: 17th Feb 2009, 16:32 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 19:07
