I am trying to convert a .dts to 6 wavs... and I am doing it in two different pcs now, both on windows xp. The problem is:
If I use the HypercubeTrancoder, it either close itself when I try to load the DTS file, or it load the file and give me a message saying "unable to render file. Perhaps, some filters missing"
I tried then Be Sweet, using AZIDTS. When I try to run it, I got this error from AZIDTS: "CreateFilter: Failed to create filter! hr=0x80040154
DShowErr: FAILED(hr=0x80040154) in CreateFilter(CLSID_DTSSource, &pReader)"
Both pcs have windvd6 platinium instaled and registred.
How could I fix any one of the problems, or is there another way to convert a dts to 6 wavs?
take a look on the www.needfulthings.webhop.org
with the besweet installer (and the including dll; ax -> there is a seperate installing routine for this) and azidts the decoding should work (as it did for me)
-> WINDVD 6 shouldn´t be a trial version!
please give feedback
CYA Daphy
[/quote]
BEST WAY TO CONVERT DTS TO WAV OR MP2:
you need the "DTSWAV DS Filter" from http://hypercube.is.dreaming.org
you need the "DTS / AVI Filters" from http://www.doom9.org
you need the "Cyberlink Audio Decoder" from PowerDVD 5 Deluxe
use Hypercube Transcoder from http://hypercube.is.dreaming.org
set the frequency and the input frequency to 44100 if needed
select "DirectShow Processing"
select "WAV Engine (single 6ch file)" or "MP2 Engine"
right-click on the "Cyberlink Audio Decoder", click on settings/properties, select 6 speaker -
daphy, the site is not opening.
deckard8: i've got this files.. now what? I installed Power DVD, and get all the .ax files from the audio filter folder, pluz the ones from the "DTS Avi Filters" and put them on the hypercube\filters, but I still got the message "unable to render file. Perhaps, some filters missing" when I try to open a DTS...
Using the DTS2WAV it try to create a 2 channel wav file (not 5ch), and still I got a error message at the end. -
works fine here, please try again!daphy, the site is not opening.
CYA Daphy
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How can I make a .dts from wav's ?
By Robertus in forum AudioReplies: 2Last Post: 5th Jul 2010, 15:20 -
Editing/Trimming a DTS Wav
By ranosb in forum AudioReplies: 12Last Post: 21st Jul 2009, 02:06 -
6-Channel Wav to AC3 and DTS
By kerpal in forum AudioReplies: 8Last Post: 9th Feb 2009, 09:10 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 03:23
