Hi I have a divx with a 512 X 384 resolution, when I convert (TMPGEnc) to mpeg-1 and burn it using nero,when I play it on my awia XR-DV526, the bottom subtitles are cut off. any suggestions on how to fix this
Actually the subs are not cutted off. Play the mpeg with a software player and you will see, the subs are still there.
The problem is that a TV screen does not display the whole picture (overscan), so I suggest to add borders to all sides. You can do that with TMPG, if you don't know how to do it, tell me the target resolution of the MPEG. Unfortunately you have to reencode. -
I dunno what my target resolution is, but i don't mind if there's a black border around the image as long as u can see the subtitles
If you load a VCD NTSC template, the target resolution will be 352x240 or SVCD PAL is 480x576 for example.
OK, when I do a divx to MPEG conversion I go for XVCD PAL 352x576, that I use as target res in this example.
Go to the advanced tab, select video arrange method "center[custom size]" and type 320x552.
It should keep the aspect ratio 768 (horizontal PAL res)-32=736, 736/1,333333333333(aspect ratio)=552.
On the video tab set size: 352x576, so TMPG will add the following borders:
left 16, top 12, right 16, buttom 12
That should be enough to see the whole picture.
Hope it helps.
TMPGEnc DVD Author 3 cuts off subtitle text
By headless chicken in forum Authoring (DVD)Replies: 8Last Post: 8th May 2010, 04:49 -
Question how to make multiple cuts with DVD Shrink
By jimdagys in forum EditingReplies: 9Last Post: 20th May 2009, 19:19 -
End of movie cuts off on PC + regular DVD player but not on Mac
By xwr321 in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2009, 11:18 -
The video is cropped on my TV, subtitles are trimmed/cutted/cuts off
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 15th Dec 2008, 22:22 -
I burn a DVD and then when played in a DVD player it cuts off after 50 mins
By uk_rose in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2008, 20:43
