I thought I had seen a tutorial for this once upon a time, but can't find anything now.
I have an already authored and burned compilation DVD with two DVD movies on it. Is there a relatively simple way to add menus to it now? Asking for simple only because if it is time consuming, it's not important enough to go thru the process. Both movies are separated by about 10-15 seconds, and can be navigated easily by skipping from one to the other. But I'd just prefer to have at least a main menu to distinguish between the two, and link to the individual movies. I'm not asking about making the menus (I have that handled). Only the best process for adding a menu to the compilation...
Thanks!
Not possible without reauthoring...
From a VMGM menu (more or less the 'main root menu' on a DVD) it is only allowed to jump to another menu (it may be an invisible menu), not directly to a movie. -
I assume both movies part of the same titleset ?
If you can get them into different titlesets, it is quite easy with TMPGEnc DVD Author to import both movies using the Add DVD Video button and reauthor without re-encoding.If in doubt, Google it. -
Thanks, I appreciate it the responses.
They are in separate title sets, so I can try DVD Author. I only want a simple menu, and nothing flashy or with transitions or motion. -
I didn't say anything about reencoding. Reauthoring is possible with a bunch of software: TDA, DVDLab, dvdauthor (therefore also dvdauthorgui and GUI for dvdauthor)...Not possible without reauthoring...
I knew encoding wasn't the intended reference borax. I hadn't thought of DVDLab for reauthoring. But since I use DVDLab Pro for authoring (and menus of course), it'd be just as easy to use that. Didn't really like the menu making process in DVD Author anyway.
Thanks again! -
Try using Titlewriter - If your menu doesn't contain cell commands and is viable (working on a dvd) it should work and doesn't require reauthoring. Otherwise You could also use a generic - Theres one for 2 Movies
Titlewriter Files are Located At:
http://www.dvdshrink.info/titlewriter/
Add subs to existing authored DVD/Keep original Menus?
By louv68 in forum Authoring (DVD)Replies: 4Last Post: 19th Feb 2012, 18:56 -
Adding subs to DVD (keep menus) - CONFUSED!!!
By ZQX in forum SubtitleReplies: 8Last Post: 11th Aug 2008, 03:18 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 01:05 -
adding subtitles to an authored DVD
By exekutive in forum ffmpegX general discussionReplies: 1Last Post: 29th Dec 2007, 11:20 -
Authored DVD with GFD, fine on TV, no menus when playing on computer.
By towtruck in forum Authoring (DVD)Replies: 6Last Post: 8th Jun 2007, 17:40
