I have been given a few DVD DATA DISC with some movies on them, i have dumped them on my pc for converting and burning. The problem is that i can watch them fine on my pc but when i go to convert them to DVD or burn them as a SVCD the screen stays all green. Im using WINAVI to coonvert and NERO6.3 for burning. Can anyone tell me why this is happening, or give me some ideas. THX![]()
My guess is that they are DIVX or XVID and you have the wrong codecs installed. If they are DIVX, try TheFilmMachine, you may have better luck. Run them through AVIcodec or Gspot to see what they are made of.
Hello,
I agree with redwudz - crappy XviD codecs always caused me green screen!
To EASILY convert my DVDs to DivX AVI I use DrDivX. <- I sequentially rename all VOBs that relate to the ONLY film. I plop the first VOB file in the sequence into Dr.DivX & then a few clicks of the mouse & a 6 hour wait & hey presto it's done. Minimum of f-ing about required!
AndyWork you bloody thing....
VRO conversion problems
By stellabelch in forum Video ConversionReplies: 3Last Post: 14th Oct 2009, 06:22 -
Conversion problems
By djtommye in forum DVD RippingReplies: 8Last Post: 16th Oct 2008, 02:13 -
VC-1 Conversion Problems
By UHD4096P in forum Blu-ray RippingReplies: 3Last Post: 23rd Aug 2008, 00:40 -
quality problems after conversion
By blubot in forum Video ConversionReplies: 16Last Post: 17th Jun 2008, 10:08 -
film conversion problems
By hobo20212 in forum Newbie / General discussionsReplies: 7Last Post: 9th Dec 2007, 07:52
