  1. Member golfnut's Avatar
    Sep 2003
    I have been using Prodisc DVD+R 4X White Inkjet Discs purchased from Rima for quite some time and have never had a problem until the last order received from Rima, only difference is they are 8X not 4X. Media code is Prodisc RO3. I have burned 4 straight coasters on the first four tries. I get error message from DVDDecrypter and DVDINFOPRO about 85-95 thru the verification so the errors are near the end of the burn. I use a Plex 708 writer and burn at 4X eventhough they are 8X. Did I just get a bad batch of discs from Rima or could there be something else wrong. I burn using Derypter/Shrink software only which I have uninstalled and reinstalled and still have the problem. Any advice you could share with me would be greatly appreciate. By the way the discs I am burning are brand new, no scratches or fingerprints.
    Decrypter error reads:
    I/O Error
    Device:[1:1:0] Plextor DVDR PX708a 1.08 (E (ATA)
    Scsi Status: 0x02
    Interpretation: Check Condition
    CDB: 28 00 00 1a fb 80 00 00 01 00
    Interpretation: Read (10)-Sector: 1768320
    Sense Area: fo 00 03 00 id fb 80 0a 00 00 00 00
    Interpretation: L-EC Uncorrectable Error
    Thank You,
    GolfNut
  2. Member RickTheRed's Avatar
    Aug 2004
    Up north
    I also have problems with these disks.
    I have tried with two different burners, with very poor results.
    Although they were not coasters, the test results were amongst the worst I have seen so far. It was also confirmed by the playback test: freezing in almost all players.
    My burners do not like them.
