Hi
I´m a newbie in this.
Using Sefys great guide i´ve use the following:
Smartripper->DVD2AVI->TMPGEnc->and then Burn.
Or I convert divx to mpg using TMPGEnc.
I works just fine, but how do I get the subtitles? If I use FlaskMPEG insted of TMPGEnc, I can select the subtitles. Whats the best way to get my subtitles in the rip?
Another one... How do I compress the .mpg file, so it fits on one CD?
TNX M8s
https://www.videohelp.com/phpBB/viewtopic.php?topic=66009&forum=11
To fit a mpg on 1 CD you have to lower the bitrate. Use a bitrate calculator from the tool section. Rule of thumb, the lower bitrate the worse quality. -
The Classical Guide doesn't support subtitles, you should use Flask or DVDx for subtitles, it would be much easier, as for fitting it into a single CD, you can either try using one of my Templates (SeVCD/SxVCD) or like Truman said, use the Bitrate Calculator to reduce the Bitrate per the CD size, but this will reduce quality, if you have an extremly long movie (over 100min), then I would personaly recommand you split it to 2 CD's instead and then boost the quality per CD.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
How to compress DV avi
By marti252 in forum Video ConversionReplies: 12Last Post: 7th Dec 2009, 02:12 -
compress video
By avextraxjp in forum Newbie / General discussionsReplies: 2Last Post: 4th Dec 2009, 03:43 -
Can i compress a
By YOURCONNEXX in forum Video ConversionReplies: 4Last Post: 9th Dec 2007, 12:03 -
Help with subtitles, compress avi
By hello123 in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2007, 09:41 -
how do you compress video
By wan2no in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 13:21
