Hello,
I just set up my durabrand home theatre in a box from Wal-Mart. I was just wondering if i can turn the surround sound off and just listen to the audio through the TV??? Does anyone know how to do this?
Hello,
Did you turn the volume up on the tv itself??? (not trying to be smartalec but you got to check the basics).
Are you asking if the tv can do virtual surround sound??? You'll have to check the manual for that.
Maybe you could give a little more detail and we could help more.
Sorry for the lack of detail.
I have these speakers and subwoofer hooked up to create surround sound. Now somtimes i dont want the surround sound on and i want the audio just to come out of the tv speakers. Now is there a way to do it, turn the surround sound off and just listen the tv speakers. Does anyone have this brand and knows how to do it? -
Hello,
Um... Just turn off the receiver and use the tv as if you had no surround sound (use the tv remote). That's my suggestion.
Chances are you are running the DVD player directly to the receiver with only the receivers Video out (or DVD players Video out) reaching the TV. Assuming your TV has component video in, send the audio RCA cables to the TV while keeping the optical cable running to the receiver.
Turn off the receiver, and in the set up mode on the DVD player choose the audio setting of Stereo or Mono or whatever isn't surround.
Should be fine.
PC to Home Theatre
By paulag in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2010, 07:20 -
Home Theatre 'Lite'
By Seeker47 in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2009, 13:39 -
PS3 to Home Theatre System
By dhyane in forum Newbie / General discussionsReplies: 3Last Post: 28th May 2009, 09:51 -
LG HE903 PAW (theatre in box) Region-Free Hack?
By duckysan1 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 11th Dec 2008, 14:10 -
How to get the TV audio thru Home Theatre (Samsung)
By jaisankarm in forum Newbie / General discussionsReplies: 3Last Post: 25th Aug 2008, 19:34
