hello all,
I have 2 Xvid files that I'd like to butn into 1 single dvd to play on tv dvd player.
How do I convert these 2 files (.avi) to 1 file?
Do I really need to convert or can I burn them with nerovision express on dvd?
thanks in advance
use VirtualDub to join them then use TMPGEnc or TMPGEnc DVD Source Creator to convert the joined .avi to DVD.
Hope this helps -
thanks
I saw the virtualdub guide in the edit section
but virtualdub says that unable to locate xvid decompressor
I have installed ffdshow the one released octiber 12th and it still
doesnt work
have any idea? -
Que? Encode them to mpeg 2 (see AVI to DVD). Then author the 2 mpegs as 2 parts of the same title. Do not join them first. There's just trouble up that road. Install latest XviD codec. But really - no need for VirtualDub in this case.
/Mats -
what types of trouble if you join first mats? I've joined and didn't have any trouble/problems
Good for you. Sync problems, different codecs/bit rates & cetera can cause problems, and are best avoided, specially if there are ways when this step isn't needed.
/Mats
How can I take the clips from movies/DVD's and make them into videos ?
By jackbruce in forum EditingReplies: 5Last Post: 14th Nov 2011, 00:08 -
How to make a compilation of 4:3 videos and 16:9 videos together on a dvd?
By pedrotc2002 in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2010, 18:35 -
how do I make a DVD with Divx or Xvid videos and have a menu that works
By Onceler2 in forum Video ConversionReplies: 3Last Post: 25th Jul 2008, 20:14 -
convert xvid, rvmb videos to DVD video_ts have two black bars
By rock in forum Newbie / General discussionsReplies: 6Last Post: 18th Dec 2007, 22:33 -
make music videos DVD
By litueche in forum Authoring (DVD)Replies: 3Last Post: 14th Dec 2007, 08:35
